Nema 34 face plate
6 years 5 months ago - 6 years 5 months ago #169498 by macsddau@linuxcnc
I have Chinese 34HS5802 motors 1600 Oz_in for my DIY CNC router. It is not reassuring :(
Last edit: 6 years 5 months ago by macsddau@linuxcnc.
6 years 5 months ago #169499 by phillc54
Replied by phillc54 on topic Nema 34 face plate
BeagleBrainz wrote: Funny how no one suggested make a new one ;)
I guess you would probably need a CNC thingy for that. :silly:
6 years 5 months ago #169513 by alkabal
Replied by alkabal on topic Nema 34 face plate
Hi
You can't drill hole, do tread and add a custom adaptor plate ?
Br
6 years 5 months ago #169566 by Todd Zuercher
Replied by Todd Zuercher on topic Nema 34 face plate
3 of the 4 bolts should still, hold. I'd attempt to try to us it as is. Especially if you have the mounting recess milled with reasonably tight tolerances.
6 years 5 months ago #169640 by kjames
Replied by kjames on topic Nema 34 face plate
Thanks all,
Yes, it is a 23 - I had my fingers one key too far to the right when typing :)
I did think about milling a new one, but I'm having a few backlash issues so once those are addressed..
I am currently using it as-is, the three bolts do still hold (just) - I'm using an extra nut on the face side to stand it off the mounting plate so I don't do the same again until I can get a mounting plate milled with a recess.. Hopefully it'll hold together.
If (when!) I get a replacement milled I'll post pictures up here ;)
6 years 5 months ago #169654 by Mike_Eitel
Replied by Mike_Eitel on topic Nema 34 face plate
If you still able to mill, i thought you can not, you can make a 'plate' for the end of your motor and use long bolts/screws to additionally "press' the motor from his rear side..
Not beautiful bot probaby working.
Mike
Time to create page: 0.408 seconds
