Thanks, step timing value was given by L297 choice.tommylight wrote: The step timing is to short, so might want to raise that, try 5000.
Thanks for your help !bbsr_5a wrote: the isel always use a charge pump
in education center i got the same version 2 with Z break
i did get rid of the C10 and went to a standard 5USD Mach3 5Axis bob
this benefits the full RPM controll of the Spindle the extra controll of the CASE Frame Version2
and of cause the option to go ETH with the 7i92
fast cabeling as plugs to fit isolated cables not the junk of the isel internal
I'm not aware of this, nor the consequences... I just plugged the parallel port to the pins of the 3 drivers via the back PCB and socket.bbsr_5a wrote: !! ATTANCIAN!!
the isel V1 uses the H-brige as a GND so the motors 8wire got +24V/48 fixed and the drivers pull them down for a step
MAKE sure you are handeling this
