how to calculate the torque for my CNC project ?
18 Jul 2020 05:39 #175016 by i34a23
Hello,
Im new and I would make a large CNC machine for my final project career.
the working area for the CNC is about 1.5 meters x 2.5 meters, and I wondering how is the correct way to calculate the enought torque to work in wooden, aluminium or metal for this CNC maching.
at the moment I supose that I need consideer:
- weight of the X axys structure
- torque needs to milling the material
- torque of the motor in Z
but I wondering if exist an "academic" way to do it. just to not mistake in the choosen of the motors.
sorry for my english, I hope can be understable.
  • Moderator
  • Moderator
18 Jul 2020 13:54 #175036 by tommylight
Replied by tommylight on topic how to calculate the torque for my CNC project ?
Ola,
Is this your first attempt at building a machine?
There are some books about it, but the only good one was an older PDF floating the net several years back.
There are plenty of information on the net, but it does require a lot of reading, and there are some calculators for the torque and speed of the machine regarding motor choice.
18 Jul 2020 21:31 #175083 by rodw
There is an academic way and its probably worthy of a final year project on its own.
This may get you started www.machinedesign.com/motors-drives/arti...rs-for-linear-motion
but we did find an error in their methodology so don't just use it without confirming the maths at every step.
19 Jul 2020 01:59 #175095 by i34a23
yes, its my first attempt with cutting cnc machine, previosuly i have working in 3d printed machine project with optimal results.
anyway, if you can share the title of the book, I'll appreciate.
thanks
19 Jul 2020 02:00 #175097 by i34a23
thanks for the link rodw, I will study and share any issue about the design process.
19 Jul 2020 03:16 #175100 by ihavenofish
Replied by ihavenofish on topic how to calculate the torque for my CNC project ?
Yaskawa makes an app called sigmaselect. You enter in all the parameters of your machine and it will tell you what motors you need. It's meant for their motors of course, but the data can be applied to most others.
To get an idea of the force you need to input for cutting various materials, try one of the calculators online. Kennametal has a good generic one. Material doesnt really matter much, pick aluminium and punch in the heaviest cut your spindle can manage. It will give you the tangential force on the machine, which you would enter into the yaskawa calculator as a load. You may want to add 50-100% as a buffer for safety.
As a basic guide to start, a large but light weight router with a low pitch screw, direct drive needs something in the 400-750w range. Higher pitch screws, faster acceleration, rack and pinion, larger diametre screws or heavier machines may need bigger motors. Gear and belt reductions may let you get away with much smaller motors.
If you intend to use steppers, the same rules apply, but you need to pay attention to the torque at speed at the voltage you are using. Bigger doesn't always end up better when you want to go faster. 10000oz-in doesn't help you if it drops off at 400rpm and you need to go 2000.
19 Jul 2020 03:21 #175101 by i34a23
a direct drive motors must be used with some kind of encoder to control the turns ? anyway I always thought in stepper motors, like NEMA 23 or 34, I just want to be sure to use the correct one.
Anyway, the main project is thinking to work just with wooden, but its important for me give support to use in metal sheets, like aluminuim too.
Time to create page: 0.990 seconds
