Calculation for MOD1 spur linear travel distance per rotation
- radek_marko
- Thank you received: 18
I'm trying to confirm my calculations for the travel distance per rotation on my CNC machine
I have MOD1 rack and pinion on x-axis and dual y-axis. All of them are driven by NEMA34 (200 steps per rotation), 50:10 pulley reduction gearbox with the output shaft equped with MOD1 15T spur.
My calculation is as follows:
Pitch Diameter (d) for MOD1 15T is 15mm.
Travel distance per rotation of end shaft MOD1 gear is from the circle circumference =>
2 * Pi * r
or
Pi * d
So in my case 47.1238898mm.
The output shaft is connected to the motor via 5:1 reduction, so one rotation of the motor is 9.424777961mm of the linear travel.
I found the following formula for setting the scale:
For "scale" i use "40" since i have full step drives connected to 200 step/rev
(1.8 degre/step) motors attached to 5mm/rev ballscrews. This is simple
math: steps per rev/mm per rev, in my case 200/5=40.Following this example, I will have SCALE value for INI file as 200 / 9.424777961 = 21.22065908.
BTW - The calculated value do not correspond to my current INI values. Current INI does work with massive inaccuracy in the travel distance
Am I right or my calculation is totally incorrect?
P.S. Later on I will feed these details into stepconf and will see if it will get the same result.
- Thank you received: 2177
math: steps per rev/mm per rev, in my case 200/50=40.
Note that the math at the end is wrong: it should be 200/5=40
So your calculation should be 200 / 9.424777961 = 21.22065908 to get steps/mm
- radek_marko
Can you confirm that my logic and the calculation formula correct?
- Mud
- Thank you received: 25
The empirical way is to set scale to, for example 10, and command a move say 10mm and measure the length actually traveled and then calculate the correction required.
This is my usual method.
- anfänger
- Thank you received: 269
There is a unite easy way to do this. The tooth pitch ist module x pi
So the circumference here is 1xpix15
So travel per step is 200x5/15pi = 21,2206591 steps / mm
But i would always double check by going 10mm with a dail indicator as a reference.
- radek_marko
Are you not using microstepping?I'm a complete newbie - so sorry for the lame answer - Yes, I think I'm microstepping as my driver settings are 400 steps (min on DM860A) and in the stepconf I have put 200 steps and 2 in "Driver Microstepping" filed...
So, that means I need to use calculation based on 400 steps per revolution?
(2 * 200) / ((15 * Pi) / 5) = 42.44131816
(<microstepping> * <steps per rev>) / ((<pitch diameter> * Pi) / <gear reduction ration>)
scale tells linuxcnc how many steps it needs to send to the motor drive to move the axis 1mm.
- Mud
- radek_marko
What a big surprise - the theoretical calculation of the SCALE checked in the reality was spot-on on 1600mm of x-axis movement and just a few mm out of expected move on 3100mm on y-axis!
Again - thank you for your support!
