Un-used Tachometer
  • hoffb77
  • hoffb77's Avatar Topic Author
  • Senior Member
  • Senior Member
06 Oct 2020 16:38 - 06 Oct 2020 16:40 #185096 by hoffb77
Un-used Tachometer was created by hoffb77
What should I do with the tach outputs I wont be using? Id prefer not to open up the servos just to remove them. Is there a proper way to terminate them?
xyz 90v dc servos
Thanks!
Last edit: 06 Oct 2020 16:40 by hoffb77. Reason: punctuation
  • Moderator
  • Moderator
06 Oct 2020 16:40 #185098 by tommylight
Replied by tommylight on topic Un-used Tachometer
Isolate the wires.
  • hoffb77
  • Senior Member
  • Senior Member
06 Oct 2020 16:43 #185099 by hoffb77
Replied by hoffb77 on topic Un-used Tachometer
That's what I've been doing with no issues I know of. I was curious if anyone felt differently.
05 Nov 2020 05:43 #188373 by rootboy
Replied by rootboy on topic Un-used Tachometer
Keep in mind that depending on your tach, your open circuit voltage could be as high as 250 volts (gleaned from both Servo-Tek and Baldor specs). Probably far, far less than that.
And it's no worse than what you would find by poking around elsewhere in your system. Just be sure to isolate it well.
But if it were me, I would lean towards removing the brushes from the tach if that was possible.
The following user(s) said Thank You: hoffb77
  • hoffb77
  • Senior Member
  • Senior Member
14 Nov 2020 00:26 #189280 by hoffb77
I have them ran to a small din rail block up in the corner and out of the way. I could put a meter on them and see what their output is at rapid. They are MSI servos and drives on a Millennium 4200/Tree J-425. I haven't been able to find a lick of documentation for them. So when I had a problem with one drive they all got replaced. I'm curious to see what they output.
Time to create page: 0.792 seconds
