Another way to drive a router
  • Mike_Eitel
  • Mike_Eitel's Avatar Topic Author
  • Platinum Member
  • Platinum Member
04 Jan 2021 10:58 #194027 by Mike_Eitel
Another way to drive a router was created by Mike_Eitel
I'm not in routers, but i think an interessting idea for long distance
Mike
  • Moderator
  • Moderator
04 Jan 2021 11:53 #194029 by tommylight
Replied by tommylight on topic Another way to drive a router
Servobelt has something silmilar, it is a very nice belt drive, for sure.
But i would have used the other side, having two separate matching surfaces requires very high precision, or the belts will grind .
05 Jan 2021 00:47 #194102 by rodw
Replied by rodw on topic Another way to drive a router
I wondered if that did not actually let the belt adjust for different tensions. But I think doing it the way you do is just as good
  • Moderator
  • Moderator
05 Jan 2021 01:09 #194108 by tommylight
I do like this solution and by far it beats everything belt or rack/pinion for light loads, the only issue i have is there is no 3M double sided glue tape here, the ones i can find will undo itself before i reach the end of the belt.
05 Jan 2021 06:06 - 05 Jan 2021 06:07 #194119 by rodw
The best 3m double sided tape is applied with a dispenser. ATG 700 dispenser
Expensive but just super awesome to use. You can get different adhesives so get the permanent one.
Last edit: 05 Jan 2021 06:07 by rodw.
Time to create page: 0.164 seconds
