Sinumerik controlpanel with Linux CNC
5 years 8 months ago #199172 by Aciera
Speaking of Profibus, I just found this:
bues.ch/cms/automation/profibus.html
Explicitly mentions integration of Profibus into LinuxCNC.
Maybe somebody finds this interesting. I have no experience with this though.
5 years 8 months ago #199490 by Onkelmat
Does someone know of the matrix works ? is it like an Keyboard "Collum/Row" array or is there some brainbugs logic ? As far as I distrust Siemens i think they won´t go the whole mile to encrypt their peripherals to a certain point.
Has anyone access to some internal Documents ? or some extra information.
5 years 8 months ago #200158 by andypugh
Onkelmat wrote: Does someone know of the matrix works ?
If you can find simple row-column pins then LinuxCNC has:
linuxcnc.org/docs/2.8/html/man/man9/matrix_kb.9.html
Which can work with GPIO or (better) with a Mesa 7i73.
And then there is a new HAL component that I am keen for someone to try out properly:
linuxcnc.org/docs/2.8/html/man/man1/sendkeys.1.html
5 years 7 months ago #200813 by JimPanski
Aciera wrote: Speaking of Profibus, I just found this:
Hi@all!
I have the same MCP Panel from the first pic here on my mill but didn't come to a solution for using it.
There are different types of it available. Ones with idc headers (maybe simple row/column) and also different types of bus connection. Newer ones with profinet may won´t actual be usable for linuxcnc machines.
The older idc ones may will work but there is soo much wiring and i think with those leds onboard the wiring will be much painful..
So a bus connection would be really great.
My MCP comes with a MPI bus. So pyprofibus may also not be helpful in this case.
I really want to try that panel connected to a RS485 converter to see if its usable but I honestly don't know how to start.
Cheers
Conny
5 years 7 months ago #200856 by andypugh
The IDC one definitely looks to be matrix-wired. It should be possible to mount a 7i73 on the back of it and make it into a smart-serial device.
5 years 7 months ago #200914 by JimPanski
Hi Andy,
yeah totally. But what about the button LEDs are there so many outputs on the 7i73 free for it?
For reference: already posted pics of the pcb here forum.linuxcnc.org/30-cnc-machines/34845...it-with-7i76e#113857
do you also see chances to get this type of mcp working?
Conny
Time to create page: 0.062 seconds
