Sinumerik controlpanel with Linux CNC
5 years 7 months ago #200919
If there is an LED for each button, maybe not. Though Charlieplexing might help.
That looks like a lot more than a simple matrix-wired keypad. I think that one would be a challenge. Is that really the same as the one in forum.linuxcnc.org/30-cnc-machines/41429...-cnc?start=10#200813 ?
Replied by andypugh on topic Sinumerik controlpanel with Linux CNC
JimPanski wrote: yeah totally. But what about the button LEDs are there so many outputs on the 7i73 free for it?
For reference: already posted pics of the pcb here forum.linuxcnc.org/30-cnc-machines/34845...it-with-7i76e#113857
5 years 7 months ago #200930
by JimPanski
Replied by JimPanski on topic Sinumerik controlpanel with Linux CNC
Charlieplexing sounds interesting - but it has the limitation for one led at a time
Yes, these pics are from my panel (but mpi type) which is the same type as Onkelmat postet in the first post at the first picture here in this thread.
Mine was connected by MPI bus on the S7 plc on the sinumerik FM-NC.
After I understood that this is no simple serial connection I was searching the siemens docs and found the other types of it but with different connection types.
It would be really nice to get away connecting it by a bus connection rather than throwing it away - buy matrix type of it - buy 7i73 - connect gazillions of wires :dry: ...
5 years 7 months ago #200936
Typically you cycle between them very rapidly (and over-drive them) and use persistence of vision to make it look like they are all lit.
JimPanski wrote: Charlieplexing sounds interesting - but it has the limitation for one led at a time.
5 years 7 months ago #201459
by JimPanski
Yes of course. Like on the 7 seg. LED displays..
Do you may have ideas how its possible to use this mpi bus type of panel?
BR
Conny
BR
Conny
5 years 7 months ago #201467
Google tells me that MPI is RS485. So some sort of protocol analyser (wireshark?) might help figure it out.
- Mike_Eitel
- Thank you received: 183
5 years 7 months ago #201520
by Mike_Eitel
Replied by Mike_Eitel on topic Sinumerik controlpanel with Linux CNC
Mpi has quite some common part with old profibus. Can't remember witch one is a subset of the other. Mpi is newer, think it has more possibilities.
Time to create page: 0.065 seconds
