Brother TC-225 Retrofit and Robot integration
5 years 7 months ago - 5 years 7 months ago #202150 by andypugh
Try editing the apt repository to include "non-free".
Either edit /etc/apt/sources.list directly or go to the repository settings in synaptic and add it there.
deb http://deb.debian.org/debian buster main contrib non-free deb-src http://deb.debian.org/debian buster main contrib non-free
Last edit: 5 years 7 months ago by andypugh.
5 years 7 months ago #202183 by PCW
Note that you probably do not want to enable the built in WIFI as they tend to be very bad for latency (a better choice is an external USB-->WIFI or USB-->Ethernet dongle)
The built in Realtek 8111 Ethernet is supported so should show up.
5 years 6 months ago #204514 by timfaber
Okay so I gave it another go, I've got debian 10 buster from linuxcnc.org. did the network setup and pinged 10.10.10.10 response time was between .12 ms and .18ms
Now the problem is that mesaflash did not find my 7i97, I've got mesaflash version 3.4.0 prep
Anyone got an idea what I might be doing wrong?
5 years 6 months ago #204518 by PCW
What does the command
ip a
report?
5 years 6 months ago #204519 by timfaber
Ip a reports the following
5 years 6 months ago - 5 years 6 months ago #204520 by PCW
Did you set mesanflash's address?
mesaflash --device ethernet --addr 10.10.10.10 --readhmid
Last edit: 5 years 6 months ago by PCW.
Time to create page: 0.301 seconds
