Well in the mean while i tried other options, got a new install and followed:
forum.linuxcnc.org/9-installing-linuxcnc...easy-install?start=0
Now i run into other problems,
./install.sh
Hit:1 http://security.debian.org/debian-security buster/updates InRelease
Get:2 http://buildbot.linuxcnc.org buster InRelease [37.8 kB]
Get:3 http://buildbot.linuxcnc.org buster/2.8-rtpreempt amd64 Packages [25.7 kB]
Fetched 63.6 kB in 2s (33.7 kB/s)
Reading package lists... Done
W: Skipping acquire of configured file 'buster/binary-amd64/Packages' as repository 'http://buildbot.linuxcnc.org buster InRelease' does not seem to provide it (sources.list entry misspelt?)
Building dependency tree
Reading state information... Done
Package gdebi is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
Package wget is not available, but is referred to by another package.
E: Package 'gdebi' has no installation candidate
E: Package 'wget' has no installation candidate
E: Unable to locate package linux-headers-4.19.0-9-common-rt
E: Couldn't find any package by glob 'linux-headers-4.19.0-9-common-rt'
E: Couldn't find any package by regex 'linux-headers-4.19.0-9-common-rt'
E: Unable to locate package linux-headers-4.19.0-9-rt
E: Couldn't find any package by glob 'linux-headers-4.19.0-9-rt'
E: Couldn't find any package by regex 'linux-headers-4.19.0-9-rt'
./install.sh: line 4: wget: command not found
sudo: gdebi: command not found
Executing: /tmp/apt-key-gpghome.oatQF0IZPq/gpg.1.sh --keyserver hkp://keys.gnupg.net --recv-key EF1B07FEE0EE663E
gpg: key EF1B07FEE0EE663E: "LinuxCNC Buildbot <nomail@linuxcnc.org>" not changed
gpg: Total number processed: 1
gpg: unchanged: 1
Hit:2 http://buildbot.linuxcnc.org buster InRelease
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
linuxcnc-uspace : Depends: libboost-python1.67.0 but it is not installable
Depends: libmodbus5 (>= 3.1.4) but it is not installable
Depends: libreadline5 (>= 5.2) but it is not installable
Depends: libudev-dev but it is not installable
Depends: tk8.6 but it is not installable
Depends: bwidget (>= 1.7) but it is not installable
Depends: libtk-img (>= 1.13) but it is not installable
Depends: python2.7-glade2 but it is not installable or
python-glade2 but it is not installable
Depends: python2.7-imaging but it is not installable or
python-imaging but it is not installable or
python-pil but it is not going to be installed
Depends: python2.7-imaging-tk but it is not installable or
python-imaging-tk or
python-pil.imagetk but it is not going to be installed
Depends: python-gtksourceview2 but it is not installable
Depends: python-gst-1.0 but it is not installable
Depends: python-xlib but it is not installable
Depends: python-gtkglext1 but it is not installable
Depends: python-configobj but it is not installable
Depends: tclreadline but it is not installable
Depends: tclx but it is not installable
Depends: mesa-utils but it is not installable
Recommends: linuxcnc-doc-en but it is not going to be installed or
linuxcnc-doc
Recommends: python-pyqt5 but it is not installable
Recommends: python-pyqt5.qsci but it is not installable
Recommends: python-pyqt5.qtopengl but it is not installable
Recommends: python-pyqt5.qtsvg but it is not installable
Recommends: python-pyqt5.qtwebkit but it is not installable
Recommends: python-opencv but it is not installable
Recommends: python-rsvg but it is not installable
Recommends: python-dbus.mainloop.pyqt5 but it is not installable
Recommends: gstreamer1.0-tools but it is not installable
Recommends: python-espeak but it is not installable
Recommends: espeak but it is not installable
Recommends: pyqt5-dev-tools but it is not installable
Recommends: hostmot2-firmware-all but it is not installable
Recommends: linux-image-rt-amd64 but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Finshed, you can reboot your PC now.
and the second method gave:
sudo apt-get -y install gdebi software-properties-common wget linux-headers-4.19.0-9-common-rt linux-headers-4.19.0-9-rt linux-image-4.19.0-9-rt-amd64
My guess something wrong with wget?
timfaber@Brother:~$ sudo apt-get install wget
