CNC Router build with HSR45 rails?
  • Catch22
  • Catch22's Avatar Topic Author
  • Elite Member
  • Elite Member
15 Mar 2021 16:11 #202365 by Catch22
CNC Router build with HSR45 rails? was created by Catch22
Hi everyone, I'm in the process of building a 4x5 cnc router I have some hsr25 rails that will go on the gantry and I also have some hsr45 rails with bearings that I bought for dirt cheap and was going to use them on the y axis, I know this is over kill but do you think it will cause any problems for me. Any input would be greatly appreciated.
Thanks Mike
15 Mar 2021 21:12 #202412 by tommylight
Replied by tommylight on topic CNC Router build with HSR45 rails?
Besides requiring beefier motors, they are just fine. More than fine, overkill as you mentioned. Those can run a metal milling machine easily.
Just the force needed to move HSR45 carriages is huge compared to what normal plasma machines use.
Go for it.
The following user(s) said Thank You: Catch22
Time to create page: 0.131 seconds
