Scara with ball spline in Z,C axis
- nhanpham
I am new in linuxcnc and I am trying to do a scara robot..
My scara is using ball spline to control Z, C axis.
With ball spline, when the C Axis rotary will do Z-axis move.
This is an issue with scarakins kinematic.
Can you help me fix this?
If you have any ideas, I will be forever grateful!.
thank you very much!!
github.com/LinuxCNC/linuxcnc/blob/master...nematics/scarakins.c
You probably need to re-arrange the calculations in the kinematicsForward and kinematicsInverse functions. The rest of the file can probably be left as-is. Do you know C?
scarakins is a simple enough module that you can compile it standalone to suit your purposes.
modify the file then
sudo halcompile --install scarkins.cYou should probably rename the file, so that next update your kins is not overwritten by the original scarakins. If you do rename the file it is important to update line 204 to match.
- nhanpham
The scarkins file is here:
modify the file thenshould compile it and install it on your system.sudo halcompile --install scarkins.c
Yes, I have knowledge about C and python
But I'm newbie for scara robot, I don't have knowledge about kinematic for ball spline.
I bought an old scara machine from IAI IX. I'm using linuxcnc to control it.
thank you for your help
I don't really understand the problem that you are having, or why it matters that there is a ball spline.
Can you explain exactly what scarkins gets wrong for your machine?
- nhanpham
With ball spline
- Z, C motor control the same vitme.
- When the C motor rotates then the Z-axis is changed
- When the Z motor rotates then the C axis does not change.
ball Spline Video 1
ball Spline Video 2
I added videos to describe how ball spline working
can we need a kinematic for Z and C?
Sorry for my English
You can probably do it it in HAL.
I think that you just pass the C axis position to the C motor and and Z + C to the Z motor. Use the HAL "sum2" component between the motor-pos-cmd output pins and the stepgen/pid input pins of the Z motor.
- nhanpham
In this case there is probably no need to edit the kinematics, though that is definitely one way to do it.
it is:
loadrt sum2 count=1
addf sum2.0 servo-thread
setp sum2.0.gain0 1
setp sum2.0.gain1 1
net J2pos sum2.0.in1 <= joint.2.motor-pos-cmd
net J3pos hm2_[HOSTMOT2](BOARD).0.stepgen.03.position-cmd sum2.0.in0 <= joint.3.motor-pos-cmd
net sum2.0.out => hhm2_[HOSTMOT2](BOARD).0.stepgen.02.position-cmd
I will test this in next week
thank you very much
- newbynobi
- Thank you received: 394
If so, please post your config, as I got the same problem on a Bosch Scara
Norbert
- nhanpham
Do you have your Scara working?
Norbert
hi, I will check it and inform to this topic next week.
- nhanpham
Norbert
Hi, you can check my config. I am testing this and it's working
loadrt sum2 count=1
#set gain for sum2 = in0*gain0 + in1*gain1
setp sum2.0.gain0 1
#gain1 = (gear-cAxis/gear-zAxis)
setp sum2.0.gain1 0.066667
#set Joint2 to sum input 0
net J2pos sum2.0.in0 <= joint.2.motor-pos-cmd
#set Joint2 to C-Axis and sum input 1
net J3pos hm2_[HOSTMOT2](BOARD).0.stepgen.03.position-cmd sum2.0.in1 <= joint.3.motor-pos-cmd
# set SUM to Z-axis
net J2posE hm2_[HOSTMOT2](BOARD).0.stepgen.02.position-cmd <= sum2.0.outPlease Log in or Create an account to join the conversation.
