Harrison M280 CNC Lathe, Setting up Threading using phototransistor
  • PhilCNC
  • PhilCNC's Avatar Topic Author
  • Senior Member
  • Senior Member
27 Aug 2021 04:09 #218856 by PhilCNC
Alright! I found the solution! In my INI file I had my pulses per revolution set to 50. It needed to be -50. It works!
  • PhilCNC
  • Senior Member
  • Senior Member
09 Dec 2021 01:19 - 09 Dec 2021 01:19 #228669 by PhilCNC
Hi everyone, I need to hook up a coolant pump and spindle controls that are usable both when using the machine for CNC and manual. What is the best way to do this? I've thought about it a bit, and I think I will need a physical switch on both to make this work.
Last edit: 09 Dec 2021 01:19 by PhilCNC.
09 Dec 2021 13:33 #228699 by Todd Zuercher
When doing manual work do you intend to still have Linuxcnc running? Or do you want to have the PC off? It may be good to keep Linuxcnc running so you can still use it for DRO and power feed purposes, and if that is the case you can use the onscreen controls that are built into the GUIs for manual control of the spindle and coolant.
09 Dec 2021 20:37 #228729 by andypugh
I have three position switches (off-auto-on) for some features of my lathe. But the logic is handled in HAL so requires that LinuxCNC be running.
Physical switches are probably the only way if you don't want to have LinuxCNC running.
  • PhilCNC
  • Senior Member
  • Senior Member
26 Mar 2022 20:44 #238423 by PhilCNC
Hi PCW, I have my machine setup with a spindle encoder and I'm trying to cut threads now, but the RPM signal is bouncing around a ton, like plus or minus 150 RPM. And my threads turn out inconsistent. Any advice?
27 Mar 2022 01:36 #238434 by PCW
Is the counting precise?
That is, if you turn the spindle say 10 turns by hand, do you get exactly
500 counts?
  • PhilCNC
  • Senior Member
  • Senior Member
27 Mar 2022 01:44 #238437 by PhilCNC
It wasn't, I ended up replacing the encoder with a nicer one, and in the end it works ok, it's just a poor surface finish which isn't an electronics issue! Thanks for your help!
29 Mar 2022 20:46 #238650 by andypugh
  • PhilCNC
  • Senior Member
  • Senior Member
29 Mar 2022 21:20 #238660 by PhilCNC
Hahaha, I remember you mentioning it, but this is the first time I've seen the picture!. I wonder who the hell thought that was a good enough idea to make it worth making a plaque for.
Time to create page: 0.107 seconds
