Bridgeport EZTrak retrofit and Z-axis
- spontarelliam
10 Jun 2021 15:19 #211707
by spontarelliam
Bridgeport EZTrak retrofit and Z-axis was created by spontarelliam
I can see that I'm not the only one thinking about retrofitting a Bridgeport EZTrak, but what I haven't seen in other posts is the desire to add Z-axis control, which is 90% of why I'd like to retrofit.
I found this quill conversion kit from MicroKinetics, but they recommend using a stepper motor to drive it. Is it possible for a Mesa card like the 7i92M to drive the original XY servo motors and a new Z stepper motor? If not, are there other suggestions?
- Thank you received: 5335
10 Jun 2021 19:16 #211723
Replied by PCW on topic Bridgeport EZTrak retrofit and Z-axis
Yes, you could use a 7I92 +7I77 +7I85S or 7I92 + 7I77 + low cost parallel port BOB for a combination analog servo + step/dir setup
Time to create page: 0.136 seconds
