Help with selecting hardware for CNC retrofit
- Norrby
5 years 1 month ago #220948
by Norrby
Replied by Norrby on topic Help with selecting hardware for CNC retrofit
Measured DC voltage over "+" and "-" see attached picture.
Also same voltage over "+" and ground "GND".
- Thank you received: 7491
5 years 1 month ago #220949
Replied by tommylight on topic Help with selecting hardware for CNC retrofit
- and gnd ? Always 0 ?
- Norrby
5 years 1 month ago #220950
by Norrby
Yes, no voltage difference over "-" and "gnd" when I run the motor.
I will check the motorspeed tomorrow when it runs on max (3V) and see if it comes up to 2000rpm/min as the motordata says.
5 years 1 month ago #220951
Nice, so it is an analog drive with +-5V or +-10V , so a Mesa 7i92 with Mesa 7i77 should do just fine or go for the Mesa 7i97 as it has both on the same board.
BTW, if you go the Mesa 5i25 or Mesa 6i25 with Mesa 7i77 route, there is no need for a parallel port.
- Thank you received: 5334
5 years 1 month ago #220959
but the analog out from the controller is single ended.
Replied by PCW on topic Help with selecting hardware for CNC retrofit
That's typical because the drive input is differential (for noise immunity)Yes, no voltage difference over "-" and "gnd" when I run the motor.
- Norrby
5 years 1 month ago #221039
by Norrby
It wasn't so easy to see the amount of rpm's but I did some more testing and managed to start a program with a lot higher speed than I was able to do in manual mode, so the driver card is -10V/10V.
Ok good, I think I'll go for the mesa 7i92M and 7i77.
Thanks for the great support!
Time to create page: 4.234 seconds
