Brother carousel encoders
2 years 10 months ago - 2 years 10 months ago #289446 by ihavenofish
Hi, I wrote the carousel routine as an o-sub, but not the axis motion to go with it yet. Someone else here has done the motion and limit swapping parts. The code is on a drive that was in the machine, but I currently can't go fetch it. It may be posted somewhere in the "tc229 adventure" thread but I'm not sure. I think it was "icebear" that did it.
I can explain how it works roughly from memory.
As you can see in the o-sub I created some variables to read and write: I read the 5 encoder tracks on inputs, and I write to outputs controlling the "brake pack" running the atc motor which I think is direction and on/off. turning it off immediately shorts to a resistor, hence the "brake".
The encoder is 4 bit BCD format, so you add those up to know what pocket you are on.
The basic procedure is:
1 - read encoder position
2 - determine the shortest path to the new tool
3 - spin the carousel in that direction
4 - *count* the deceleration track (one count, is one pocket position)
5 - when you get to the right pocket, read the deceleration track again, then wait (in my case) 200ms, and then hit the brakes.
6 - read the encoder position to make sure you have actually landed in the right spot. You will need to play with brake timing to get it to stop in just the right position.
I put a lot of error handling in to make sure nothing would move unless you were on the right tool, in position on the upper limits, etc.
BEFORE this code, you need to add code that swaps the limits form the lower to the upper, then moves the Z up to the first limit, orients the spindle, then moves up to the top "atc" limit.
Then AFTER my code you move back down to the lower limit, and swap the limits back to normal, and then resume the main program.
This gets a basic reliable operation. Fancier modes of operation I want to implement are single motion (orient on the way up as a coordinated A axis), and repositioning the table during the carousel motion.
Last edit: 2 years 10 months ago by ihavenofish.
1 year 7 months ago #325297 by Sprudelflasche
Hey, I'm working on a TC-215 conversion. Can someone tell me the pin out of the original connector (CNENC) from the tool changer encoder? Does it work on 24V DC?
Regards Tim
1 year 7 months ago #325471 by ihavenofish
It's 24v. ill have to dig for the pinout.
7 months 2 weeks ago #344248 by jefflikesbagels
Hi ihavenofish,
I am also in process of retrofitting a TC225, however I am in a different situation where the machine was completely gutted and I am starting from (almost) scratch. When you get a chance could you send us that pinout? I have the Oriental Motor brake pack and gear motor and am confident in that part, but I haven't been able to find any information on the encoder. All I have right now is a harness that has 8 wires with the following labels: 49, 50, 51, 52, 53, 54, 55, and E. My next step was to start probing each wire to determine which ones are 0V, +24V, and the 4 BCD signals. E is obviously earth ground.
I appreciate it!
Jeff
7 months 2 weeks ago #344288 by ihavenofish
unfortunately i dont have that info hand. it is probably in the tc229 thread.
Time to create page: 0.372 seconds
