Chiron FZ 18 S retrofit
03 Mar 2022 17:23 #236280 by radom
Replied by radom on topic Chiron FZ 18 S retrofit
it doesnt have one, its USFF version
  • Moderator
  • Moderator
03 Mar 2022 17:35 #236284 by tommylight
Replied by tommylight on topic Chiron FZ 18 S retrofit
OK, although i had a HP 8300 Ultra small form factor with an add on graphic card made by AMD.
Then boot in safe mode, if that works, and check the chipset, chances are it is some type of Intel 915 and as such might be blacklisted in Linux.
04 Mar 2022 08:15 #236320 by radom
I got punk'd
I unplugged the monitor, waited 10s till backlight is off and plugged it back in and now I can see the installer
  • Moderator
  • Moderator
04 Mar 2022 13:31 #236340 by tommylight
OK, that may be something wrong with DPMS or display power management when changing resolution.
Glad it works. :)
Time to create page: 0.157 seconds
