- Hardware & Machines
- CNC Machines
- PID loop-Retrofit old plasma cnc with air valve actuated z-axis low tech THC
- oeleboele
11 Dec 2021 11:37 #228868
by oeleboele
Replied by oeleboele on topic PID loop-Retrofit old plasma cnc with air valve actuated z-axis low tech THC
Thanks I will look into that
- Thank you received: 7461
11 Dec 2021 11:39 #228869
Replied by tommylight on topic PID loop-Retrofit old plasma cnc with air valve actuated z-axis low tech THC
Search google for servo tuning detailed howto, the first result should be it.
- phillc54
- Thank you received: 2100
11 Dec 2021 11:40 - 11 Dec 2021 11:41 #228870
by phillc54
Replied by phillc54 on topic PID loop-Retrofit old plasma cnc with air valve actuated z-axis low tech THC
The wcomp component could probably control your real Z axis.
linuxcnc.org/docs/devel/html/man/man9/wcomp.9.html
Last edit: 11 Dec 2021 11:41 by phillc54.
- oeleboele
11 Dec 2021 11:57 #228871
by oeleboele
Thanks, I saw your post servo-tuning, very nicely explained.
- oeleboele
11 Dec 2021 12:41 #228873
by oeleboele
The plasmac.state.out did the trick! Chill.
- Thank you received: 4138
13 Dec 2021 01:15 #228974
Replied by rodw on topic PID loop-Retrofit old plasma cnc with air valve actuated z-axis low tech THC
Just a heads up that they still make Plasmas with a Z axis that skates along for HVAC thin sheet applications. but it sounds like you have got it going!
Very cool
Very cool
- oeleboele
13 Dec 2021 08:36 - 13 Dec 2021 08:49 #228999
by oeleboele
Nice. It does indeed do a good job with pressing down warped sheet. But the drag does bother me a little
But I'm also quite happy that I got i working, now I only need to fine tune the servos. I was a bit confused about that but now I understand that the drives close the velocity loop and that the position loop has to be closed in Linuxcnc.
What still confuses me is that I can only apply very low P value. Now I have P=2.5 but when I go higher the motor starts to vibrate quite heavily. Since the standard setting and a lot of the P values I read upon in other posts are way higher it feels a bit low to me. And I have the feeling the motors are not running at full speed with this settings. My FF1=0.03 at the moment.
It is all quite new to me so I don't have a feeling jet for what could be reasonable.
Can anybody tell me this could be in the right direction?
Last edit: 13 Dec 2021 08:49 by oeleboele.
- CNC Machines
Time to create page: 0.212 seconds
