VEVOR 1.5KW Spindle Motor VFD
04 Jan 2022 12:41 #230753 by Bergy_CNC
VEVOR 1.5KW Spindle Motor VFD was created by Bergy_CNC
Hello, is this Vevor VFD supported by LiinuxCNC using 485 connections, I have found setups using the
Huan Yang vfd.
04 Jan 2022 12:57 #230754 by andypugh
Replied by andypugh on topic VEVOR 1.5KW Spindle Motor VFD
The Huang Yang driver is required because they don't actually use real Modbus.
What protocol does your Vevor drive use? You might be able to use mb2hal:
linuxcnc.org/docs/2.8/html/drivers/mb2hal.html
The following user(s) said Thank You: Bergy_CNC
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
05 Jan 2022 14:47 - 05 Jan 2022 14:47 #230869 by Todd Zuercher
Replied by Todd Zuercher on topic VEVOR 1.5KW Spindle Motor VFD
Almost any drive that supports Modbus can be controlled using mb2hal. But be warned configuring a modbus device can be quite painful, because the documentation for virtually all modbus devices is universally poor and difficult to figure out. And no two manufactures use the same protocols.
Last edit: 05 Jan 2022 14:47 by Todd Zuercher.
