Changing an Isel FB2 to LinuxCNC?
- Thank you received: 4654
07 Feb 2022 19:58 - 07 Feb 2022 19:59 #234280
Replied by andypugh on topic Changing an Isel FB2 to LinuxCNC?
Also, once you have the build environment set up to build the firmware, there is only one file to edit to build a custom one. Here is an example (that was made for me, hence the name) that contains both UART and smart-serial. The file declares what components are in the firmware, and which pins they use. [/quote]
I wouldn't get too hung-up on the firmware, it's not generally too difficult to persuade PCW to make you one.Since the 7c81 seems to come with matching firmware, this looks like the potentially easiest solution.
Last edit: 07 Feb 2022 19:59 by andypugh.
- knipknap
- Thank you received: 6
07 Feb 2022 20:33 #234287
by knipknap
Replied by knipknap on topic Changing an Isel FB2 to LinuxCNC?
I think a RS-232 to RS-485 adapter maybe would not work, because the (chain of) LS-173 uses full duplex (4 wire) RS-485, and I think RS-232 only does half duplex.
Sadly, that maybe also means that a Raspberry Hat would probably not work, because looking at the pinout of the Raspberry, it also has only two pins labels RX/TX, though I guess some IO pins may be re-purposed if the hat comes with a full duplex serial port driver.
So in summary, I still like the 7C81 option best, also because I like the form factor, I have several Raspberries lying around, and it is one of the few boards that are in stock in the EU...
Though I do like the simplicity of the HAL driver (.comp) for the serial port, this was easy to follow even for me, and I think I understand how HAL works now
. My initial confusion came from thinking I would have to translate G commands into servo driver commands in the HAL driver, which I understand now is of course not needed.
07 Feb 2022 21:07 #234289
I am interpreting it as TX+ / TX- and RX+ / RX- differential pairs. I would expect a converter to do the TTL to differential conversion.
No, as you have probably realised, you just have to convert a velocity command that comes in on a HAL pin in to a formatted data packet. At least as a starting point. Handling the driver ID arbitration and setup will add incremental complexity, but that will come quite easily once the rest is there.
- knipknap
07 Feb 2022 21:14 #234292
by knipknap
Thanks for all the help!
Ah, I see! That makes sense now. Then I'll try the serial option - that would seem to be both the easiest and cheapest approach.
- NickyDoes
23 Oct 2025 04:02 - 23 Oct 2025 04:03 #336931
by NickyDoes
Replied by NickyDoes on topic Changing an Isel FB2 to LinuxCNC?
I'm going through old Logosol posts. I'd appreciate hearing where you are on this project.
You can communicate from a PC to a chain of Logosol drives with a USB to RS-485 converter. No Mesa ports to work with.
These converters typically use a chip like an FTDI for USB-to-UART conversion, plus an RS-485 transceiver (like a MAX485) to handle the differential signaling and half-duplex operation on the bus.
RS-232 vs RS-485:
RS-485 is half-duplex (not full duplex). It uses two wires (A/B or +/-) that are shared for both transmitting and receiving - devices take turns communicating on the same pair. RS-232 is full-duplex, using separate transmit and receive lines.
The key advantage of RS-485 is differential signaling, which eliminates common mode noise and allows much longer cable runs (up to 4,000 feet) compared to RS-232's typical 50-foot limit.
RS-232: Uses separate RX, TX, and GND lines. Single-ended signaling measures voltage relative to ground.
RS-485: Uses differential pairs (A/B or +/-). The receiver compares the voltage difference between the two wires to determine logic levels. Since noise affects both wires equally (common mode), it cancels out in the differential measurement, making the signal much more robust.
RS-232 vs RS-485:
Last edit: 23 Oct 2025 04:03 by NickyDoes. Reason: Asked for a status update.
Time to create page: 0.426 seconds
