- Thank you received: 6
I wouldn't get too hung-up on the firmware, it's not generally too difficult to persuade PCW to make you one.Since the 7c81 seems to come with matching firmware, this looks like the potentially easiest solution.
So if I understand this correctly, I would only need a way to communicate over a single RS-485 UART port from LinuxCNC. Doesn't that simplify things to the point that I don't need any additional hardware? I guess I could program the Raspberry IO pins for RS-485, or to avoid latency issues perhaps use a simpler RS-485 hat, if LinuxCNC has support for that?
Of course I would still need a driver, but at least the hardware part should be simpler, I guess.
Also, once you have the build environment set up to build the firmware, there is only one file to edit to build a custom one. Here is an example (that was made for me, hence the name) that contains both UART and smart-serial. The file declares what components are in the firmware, and which pins they use. [/quote]
