2.2kW VFD over current problem
  • EragonPower
  • EragonPower's Avatar Topic Author
  • Senior Member
  • Senior Member
13 Feb 2022 19:10 #234723 by EragonPower
2.2kW VFD over current problem was created by EragonPower
Hello everybody,
Yesterday my new spindle arrived. It's a 2.2kW ER20 square spindle from VEVOR. I've connected it right away and i've started having issues right away. I'm powering the spindle with a generic HY spindle(A2-8022, 2.2kW) with whom i've powered bigger motors in the past without any problems. I've started the VFD and send the command to start rotation with my 7i76e, the spindle started rotating right away, but, as soon as i've reached the 6Hz mark the VFD freaked out and thrown an error, ERROR OC -u; Accelleration Overcurrency to be precise. The manual says that that error happens when the accelleration time is too low, so i've increased the accelleration time to it's max (650s) and tried again. Nothing changed, so i've started taking some measurements. 7.5A per phase measured both at the spindle and the VFD, roughly 3V AC of output from the VFD at 6Hz, 215V at 50Hz, 1.5 Ohm Between UV-VW-WU. I'm not really sure if any of those values mean something. I'm thinking that is probably the VFD that is faulty but again, i've used that same VFD on other motors and run just fine. I'm not sure on how to proceed, if any of you have a vage idea i'm more than happy to listen.
13 Feb 2022 19:18 #234726 by db1981
Replied by db1981 on topic 2.2kW VFD over current problem
did you set the frequencies in the drive to the matching ones for the spindle? if this is an 300 or 400hz spindle, sending full voltage lower then the nominal frequenz could damage the windings.
Is this an hf spindel? Don't try to start with 0hz or use to long accelerations times. The current at lower rpms will get to high.
  • EragonPower
  • Senior Member
  • Senior Member
13 Feb 2022 19:35 #234730 by EragonPower
Replied by EragonPower on topic 2.2kW VFD over current problem
The spindle is rated for 400Hz at 230V AC, so i think it's an HF spindle. at which frequency should i start?
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
13 Feb 2022 20:00 #234734 by Todd Zuercher
Replied by Todd Zuercher on topic 2.2kW VFD over current problem
The most important thing is to set the frequency and voltage parameters in the drive. So that the drive will properly reduce the voltage at low frequencies to prevent over current. It is unfortunate that these cheap Chinese drives and spindles are usually sold together without being configured for each other or at least a list of the proper settings.
Time to create page: 0.326 seconds
