Closed loop stepper cable questions...
- harmo
- Thank you received: 11
08 Mar 2022 23:29 #236724
by harmo
Replied by harmo on topic Closed loop stepper cable questions...
Hi Rod,
Thanks for the link, I have the Stepper Online cables for the drag chain part, but I don't have the right stuff for the limit switches and touch probe. So I'll check Treotham out. However, since I haven't even started assembly on the machine itself yet... I've probably got some way to go before I'm up to that bit.
How's your "space ship" going? Are you doing anything fun with it these days? I'm still dreaming of running my first job, so I have to live vicariously through others.
Hope you're well and enjoying the machine!
Hamish.
Hamish.
- spumco
- Thank you received: 905
09 Mar 2022 01:23 #236730
by spumco
Replied by spumco on topic Closed loop stepper cable questions...
It took me a few tries to figure out the StepperOnline encoder cables (at the motors) do NOT have the same color coding as their extension cables. The cables are nice(ish), good rubber sheathing (not PVC), fine strand for flexibility... but you're right about the shielding.
My solution was to chop the VGA connectors off close to the motors and terminate with aviation connectors that permit tying the encoder cable shield to the extension cable shield and on to chassis ground next to the drives. I don't have many miles on them yet, but so far no noise issues.
And yes, the steppers acted WAY unhappy when the encoders were cross-wired until I figured out the colors don't match and that I had a few of them crossed up.
Bonus Tip - change the permitted following error in the drive software. I can't remember what the actual setting field is named, but default is something like 1000 counts and can result in huge mechanical deviation with no drive alarm.
-Ralph
-Ralph
Time to create page: 0.106 seconds
