I Can't get the machine to do the speed I'm writing in the INI file
14 Mar 2022 21:32 #237241 by OmarAhmed-DELTA
Hello all!
I've been encountering a problem for a while now on linuxcnc. My project is a Linear Delta Robot used for milling.
My problem is, when I run the configuration file on any G-Code, the speed of the motors is slow no matter what the speed I'm putting in the INI is.
And also, when I'm setting the StepConf file, in the test-axis section on each axis the motors seem to be working perfectly in terms of speed. But when I run any G-code on the same configuration file, the speed gets reduced so much.
Another problem is an error I get quite often, which is, joint 0 has a following error. I wish someone can guide me through this error.
And thank you.
14 Mar 2022 22:20 #237247 by tommylight
What is the feed rate set in gcode?
Does the feed rate change when moving the feed slider in LinuxCNC?
14 Mar 2022 23:44 #237263 by andypugh
I think thus sounds like the step-rate required to get the desired speed is higher than the system can generate.
What is your SCALE, MAX_VELOCITY and BASE_PERIOD?
Time to create page: 0.264 seconds
