Retrofitting a MAHO MH500W '89-'90 with hand-feed
3 years 5 months ago - 3 years 5 months ago #271883 by petmakris
PCW  wrote: Well, normalizing will work but you also have to make sure the PID maxoutput does not limit the output... (and the FF1=1.0 is only as accurate as you speed measurement at 10V)
I assumed something like that but I did not have the energy required to keep digging.
Finally, I decided not to do the scaling and play with FF1 such that f-error gets minimized (starting from 1.0 / vel at 10V).
Last edit: 3 years 5 months ago by petmakris.
3 years 3 months ago #276291 by zopf96
Hi Petros,
I have the same machine at home and thinking of converting it to linuxcnc as well. What is the current status of your project? Could you give me tips on how to start and what to look out for?
Thanks for your reply :)
Kind regards
Christoph
The following user(s) said Thank You: petmakris
2 years 10 months ago #287494 by petmakris
Hello Christoph,
Sadly, I didn't get notified about you post. So, many months later, what is your current status?
The machine is working, the retrofit was succesful but I am having some accuracy issues (for now, I believe it's the ballscrews)
You can browse this repository, all my work is there.
github.com/petmakris/maho-mh500w
About tips, what is the current status of the machine? Is it in a working order?
The following user(s) said Thank You: akb1212
1 year 8 months ago - 1 year 8 months ago #322855 by H-S-W
Hi Petmakris!
I'm starting a linuxCNC conversion on a MH500W2 with a faulty Philips 432/9. Planning to use all your hard work in order to get it up and running again. I'll be using a Rpi5 and a 7I97T and three EXEs.
My first step has been to wire the mill to the 7I97T, but i have a question about the "Limit"s. In the MAHO documentation the limit switches seems to be connected in series 204-207,
did you rewire these or simply used 205,206,207 as limit X,Y,Z?
Regards,
Hampus
Last edit: 1 year 8 months ago by H-S-W.
1 year 2 months ago #333150 by simplex
Hey guys, I also wanna convert a MAHO MH500W
But I'm more of a software / mechanical guy, so any advice would help :D
1 year 2 months ago #333166 by tommylight
- DO IT!!!
- a lot of reading
- never wire everything and hope it just works, it won't
- do everything step by step, especially wiring and testing the electronics
- ask, ask, and ask again, we are here to help as much as humanly possible
Time to create page: 0.226 seconds
