I suspect that I have a velocity mode amplifier (It's an Indramat 3TRM3) because I have applied constant voltage and it was moving at constant velocity. Can you explain how to tell if it's a velocity or torque driven servo system? I can't find any information anywhere for this.If these are velocity mode drives, you must have FF1 for decent performance
Note that if you scale the analog output to the drives machine velocity in
units per second at 10V, FF1=1.0.
If you leave the default scaling of 10 (= scaling in volts), FF1 =
10/drive_velocity_at_10V
Which parameter is this scalemax? Can't find it image missing /media/kunena/emoticons/dizzy.pngFor velocity mode PID use I like to set scalemax to the drives machine units (inches or mm) per second at 10V in. This normalizes the PID loop so FF1 can be set to 1.
