- Thank you received: 3
Retrofit Precix 3 Axis Gantry Mill
- ahess
3 years 1 week ago #283814
by ahess
Replied by ahess on topic Retrofit Precix 3 Axis Gantry Mill
- Thank you received: 7491
3 years 1 week ago #283818
Replied by tommylight on topic Retrofit Precix 3 Axis Gantry Mill
From memory, AC SSR should only switch on at zero crossing, otherwise they blow up.
Not sure if they also switch off at zero crossing, though?
- ahess
3 years 6 days ago #283820
by ahess
Did a research on this, zero crossing is most common, random switching you hardly stumble upon. Checked mine are 0 crossing. Low chance the blown one was bad fabrication (Chinese)
3 years 6 days ago #283821
Chinese SSR if it says 40A, probably 10-15A is OK, above it they usually blow up. Plenty of videos on youtube about exactly that.
Get an Omron one, original if possible!
The following user(s) said Thank You: ahess
- rmu
- Thank you received: 101
3 years 5 days ago #283895
by rmu
Replied by rmu on topic Retrofit Precix 3 Axis Gantry Mill
Maybe that was already answered elsewhere:
* Did you check that really the toroidal transformer is the problem?
* For testing purposes try wiring in the light-bulb and look if it flashes when turning on/off
* crazy: are you sure you are turning off? maybe the SSR logic is inverted somewhere? if you don't run the motors on the test setup it may be possible to miss that...
- sivaraj
- Thank you received: 25
3 years 5 days ago - 3 years 5 days ago #283903
by sivaraj
Replied by sivaraj on topic Retrofit Precix 3 Axis Gantry Mill
I feel your SSR is rated for resistive load .So it fails with inductive load.
Use a Mecchanical Relay or find an SSR which can handle Inductive load.
The 1500w toroidal inductive load can create large spike during power off.
You need to arrest this.
Some SSR have build in snubber .
But your transformer is too big and spike can be larger than SSR rating .
From the schematic I believe circuit is with soft start.
I do not see any control for the NO contact shown across the P14 .
Does it has bult in timer ?. This must have an ON delay contact to avoid inrush current.
Refer below page on softstart for toroidal transformers.
sjostromaudio.com/pages/index.php/hifi-p...ansformers?showall=1
It uses two relays. The second relay will be switched on after a time delay
I would sugget use an Electro Mechanical Relay instead of SSR.
Attached a reference page from Omron's Technical guide
Last edit: 3 years 5 days ago by sivaraj. Reason: attachment
Time to create page: 2.194 seconds
