Mesa 5i25t mit 7i77 und 7i74
- pietxs
12 May 2024 00:16 #300412
by pietxs
Mesa 5i25t mit 7i77 und 7i74 was created by pietxs
Hello, the following configuration does not work for me. The 7i77 card is immediately recognized at P3 and recognized as serial port0.
Unfortunately I get an error message as soon as I try to activate the 7i74 as serial_port1. Map is not accessible.
There is no firmware bit file for this config to describe the 5i25t with mesaflash.
Does anyone have advice for me?
Hallo folgende Konfiguration läuft bei mir nicht. Die 7i77 Karte wird an P3 sofort erkannt und als sserial port0 erkannt.
Leider bekomme ich eine Fehlermeldung sobald ich die 7i74 als sserial_port1 aktivieren will. Karte ist nicht erreichbar.
Einen Firmware Bit file gibt es zu dieser Konfig nicht um mit mesaflash die 5i25t zu beschreiben.
Hat jemand einen Rat für mich?
- Thank you received: 5328
12 May 2024 03:10 #300419
Replied by PCW on topic Mesa 5i25t mit 7i77 und 7i74
Here is firmware for a 5I25T with 7I77 on P3 and 7I74 (sserial)
on P2:
Note: make sure you have the latest mesaflash before
attempting to update the 5I25Ts firmware.
on P2:
- pietxs
12 May 2024 08:53 #300424
by pietxs
Replied by pietxs on topic Mesa 5i25t mit 7i77 und 7i74
Hello, thank you very much for sending the bin file.
I uploaded via mesaflsh, everything worked.
Unfortunately, after restarting and powering down, the Done LED on the 5i25t lights up permanently.
The following commands produced this error:
halcmd: loadrt hostmot2
Note: Using POSIX realtime
halcmd: loadrt hm2_pci
hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
hm2_pci: rtapi_app_main: No such device (-19)
<stdin>:2: waitpid failed /usr/bin/rtapi_app hm2_pci
<stdin>:2: /usr/bin/rtapi_app exited without becoming ready
<stdin>:2: insmod for hm2_pci failed, returned -1
halcmd: hm2: unloading
Jumper W5 is in down position.
What did i do wrong.
With the old firmware, the 7i77 was recognized on P3 and all pins were accessible.
Thank you in advance
- pietxs
12 May 2024 09:25 #300429
by pietxs
After the 5i25 could no longer be reached, I set jumper W5 to up and restarted. Now I could access the map again. I then installed a different firmware and after --reload the done LED was off. FPGA ok.
Then I tried the following again:
pietxs@MahoMH700:~$ cd linuxcnc/Mesafirmware/5i25t_7i77_7i74d
pietxs@MahoMH700:~/linuxcnc/Mesafirmware/5i25t_7i77_7i74d$ sudo mesaflash --device 5i25t --write 5i25t_7i77_7i74d.bin
[sudo] Password for pietxs:
Checking file... OK
File type: Efinix bin file
FLASH memory sectors to write: 11, max sectors in area: 16
Erasing FLASH memory sectors starting from 0x100000...
|EEEEEEEEEEEE
Programming FLASH memory sectors starting from 0x100000...
|WWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW
Board configuration updated successfully.
Checking file... OK
Verifying FLASH memory sectors starting from 0x100000...
|VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV
Board FLASH memory verified successfully.
You must power cycle the hardware or use the --reload command to load a new firmware.
pietxs@MahoMH700:~/linuxcnc/Mesafirmware/5i25t_7i77_7i74d$ sudo mesaflash --device 5i25t --reload
Waiting for FPGA configuration...OK
pietxs@MahoMH700:~/linuxcnc/Mesafirmware/5i25t_7i77_7i74d$ halrun
hm2_pci: discovered 5i25t at 0000:01:0a.0
hm2/hm2_5i25.0: Low level init 0.15
hm2/hm2_5i25.0: invalid cookie, got 0xFFFFFFFF, expected 0x55AACAFE
hm2/hm2_5i25.0: FPGA failed to initialize, or unexpected firmware?
hm2_5i25.0: board fails HM2 registration
RTAPI_PCI: Unmapped 65536 bytes at 0x7f710e3c4000
Driver probe function failed!
hm2_pci: error registering PCI driver
hm2_pci: rtapi_app_main: Operation not permitted (-1)
halcmd:
Now the Done LED is permanently on again.
Checking file... OK
|EEEEEEEEEEEE
Checking file... OK
halcmd:
12 May 2024 17:29 - 12 May 2024 17:32 #300461
I'll take a look Monday or Tuesday, I don't have a PCI test system here.
Actually I see the issue, I accidentally made a fallback configuration
I can fix it later today
Last edit: 12 May 2024 17:32 by PCW.
- pietxs
12 May 2024 19:04 #300467
by pietxs
Thanks in advance.
At the moment I'm stuck and don't know what to do anymore. Why are these firmware files not available from Mesa?
In the documentation for the 5i25t, this exact config is listed as an option.
12 May 2024 22:47 #300476
Should fix the issue.
The 5I25t manual is just a clone of the 5I25 manual
but not all bitfiles have been built yet
- pietxs
13 May 2024 05:45 #300489
by pietxs
Thank you very much, everything is going great. Both cards were immediately recognized, as was the 7i70 attached to the 7i74.
You saved me.
You saved me.
