CNC Mill Y+/Y- axis different step sizes
- JasufKasuf
14 Jun 2024 13:27 #303007
by JasufKasuf
CNC Mill Y+/Y- axis different step sizes was created by JasufKasuf
This is my first post here so please bear with me if I am lacking any standard info or procedure in this post.
I have a 3 axis mill running linux cnc and need help diagnosing the cause for the distance difference in movement in the Y positive and negative directions. I have compensated for backlash, adjusted the scale factor, tightened the pulley, and oiled the table's lead screw but am still getting about 0.101" for every 0.1" in one direction and 0.98' for every 0.1" in the other direction. Any ideas would be greatly appreciated.
- Thank you received: 5328
14 Jun 2024 16:49 #303012
Replied by PCW on topic CNC Mill Y+/Y- axis different step sizes
Have you tried a larger distance to see if the ratio stays the same?
if its not a mechanical issue (backlash, loose couplings etc) it might be
marginal step timing or an electrical/wiring issue where the state of the
direction pin influences the step pin.
The following user(s) said Thank You: JasufKasuf
- JasufKasuf
14 Jun 2024 17:59 #303015
by JasufKasuf
Replied by JasufKasuf on topic CNC Mill Y+/Y- axis different step sizes
Thanks I got it fixed by poking around the wiring in the control board, couple loose wires that were giving intermittent signals I think.
Time to create page: 0.216 seconds
