DM542 stepper motor driver power stage light on red
21 Jun 2024 07:19 #303473
by Mabel
DM542 stepper motor driver power stage light on red was created by Mabel
Hello everyone.
I'm currently building a CNC milling machine. The milling machine is controlled via a raspberry pi 3 b+ and a Smoothieboard v1.1 with DM 542 stepper motor drivers( www.oyostepper.de/goods-1249...rittmotor.html ) and 1.8° 2A motors.
X-axis 1.8° 3 A runs via a stepper motor driver as the smoothie board can only control 2A. I controlled the two Y-axes and the Z-axis three times 2A via the smoothie board.
Unfortunately that didn't work. I had to buy two new drivers and connect them separately to Y1 and Y2 - they run in parallel. It worked until I ran the CNC and it
went too far to the left for me. I had to press the killbatten. I unplugged the entire system and turned it back on. When the control had power again, the lights suddenly lit up
The red lights on the power amplifiers. It took a while for me to figure out why. As soon as I removed the Enable + (+5V) cables from the power amplifiers, the power amplifier lights turned green again and the machine is running. When I try to plug the cable back in, the lights turn red again and nothing works anymore. Can someone tell me why this can be like that?
And I have a 1.5 KW spindle with a Huanyang inverter controlled via the rs485 breakout board. The software is CNCjs. Now I have the problem that the spindle does not run with the M3 command or only sometimes and when it runs I cannot stop the spindle with the M5 command. Sometimes it works and then it doesn't work again. Can someone please help me with this? I'm happy about every suggestion and comment.
- Thank you received: 6092
21 Jun 2024 11:25 #303485
Replied by tommylight on topic DM542 stepper motor driver power stage light on red
Not sure what is going on due to translation, but some pictures of the wiring might help, or a video explaining the issue?
21 Jun 2024 15:55 #303497
by jimmyrig
Replied by jimmyrig on topic DM542 stepper motor driver power stage light on red
Your enable pins for spindle and steppers probably go through your estop button. Make sure it is no longer pressed or jammed. Buttons can break if you hit them too hard.
The situation you describe is a lost enable wire. Trace it from your power supply, through to your drives and check for continuity.
21 Jun 2024 19:32 #303512
Replied by rodw on topic DM542 stepper motor driver power stage light on red
Like most steppers, The DM542's enable terminals are really a disable signal. It's best to leave them disconnected.
Often, estop disconnects mains power from the Stepper motor power supply so there is no point using a disable signal
Revisit applications for this once you have a working machine and understand how things work,
Moderators: cncbasher
Time to create page: 0.076 seconds
