Can you recommend belt/pulley driving source
2 years 4 weeks ago - 2 years 4 weeks ago #311281 by PhilipME
The spindle : bt-30 power head
The spindle motor : AC servo 1.5 kw max rpm 3000 rpm
torque : 5 N.M
They are not infront of me right now, but I think both have 14 mm shaft with key
intended for small milling machine.
Best regards
Philip
Last edit: 2 years 4 weeks ago by PhilipME.
2 years 4 weeks ago #311293 by Roguish
check out Brekoflex. www.brecoflex.com/
i've used them for all kinds of machines. have them on my mill tool.
The following user(s) said Thank You: PhilipME
2 years 4 weeks ago #311310 by spumco
Along with Brecoflex, B&B Manufacturing and Rainbow Precision are sources I use for belts & pulleys.
For pulley mounting where a taper-lock or similar tapered bush isn't available, keyless shaft bushings are an excellent choice.  Very strong shaft grip, excellent runout, and easy to use if you're making your own pullies from pre-hobbed blanks (or raw stock)
Before you commit to a timing belt, consider a poly-v (milti-rib, many names) profile.  They are considerably quieter than timing belts, and can still be used for a rigid-tapping setup if you put an encoder directly on the spindle. Downside is they require a bit more belt tension - and thus bearing loads - than timing belts.
If you absolutely must have a timing belt and are willing to spend a bit more than typical HTD prices, Continental's SilentSynch are almost as quiet as poly-v's.  Downside is the pulley selection is less broad than with standard timing belt profiles and they can get pricey.
2 years 3 weeks ago #311316 by PhilipME
Thank you all for the information
2 years 3 weeks ago #311337 by andypugh
www.bearingboys.co.uk
But probably only relevant if you are in the UK...
2 years 3 weeks ago #311351 by Unlogic
I've purchased all my HTD belts and pulleys from Norelem. They have all been of very high quality.
Time to create page: 0.076 seconds
