I visited all sites in the replies
regarding tapered bushing naming
for example 1108 means the max bore it can be selected for the group is 1.1 inch, and the length is .8 inches.
While my shaft is in metric system.
I found many companies list for example 1108 tapered bushing with metric shafts. Little confusing for me because , either use imperial or metric not a mix.
In all cases I will be buying pulleis/tapered bushings combination as a set, I will not try to buy them individually and try to match. Eventhough, it should not be complicated anyway just precaution.
Now I have to perform the calculations regarding torque based on the servo motor maximum torque and teeth engagement
Best regards
Philip
