Adding a DRO and want to integrate with linuxcnc, recommended hardware?
14 Oct 2024 03:11 #312027 by PCW
For SSI or BISS absolute encoders, a 7I96S+7I85 is one possibility
16 Oct 2024 18:07 #312282 by matasbuk
If you're thinking about absolute encoders and upgrading the steppers, you can also look into ethercat servos, but the encoders would be pre-backlash this way.
20 Oct 2024 01:58 #312646 by abarry
Thank you all so much for the advice. I just ordered the following:
- 7I85 4 Channel encoder 5 channel Serial RS-422 interface
- 7I96 STEP/IO Step & dir plus I/O card
- DB25M-IDC26 CABLE 18"
And for encoders:
Digital Position Readout, 3-Axis Bluetooth for HiTorque Mini Mill (part number 5514)
It looks like the Little Machine Shop DRO kit uses magnetic strips that have A/B/Z (index) encoders, so I plan to swap out their Bluetooth box for the Mesa 7I85, but since it was on sale getting the Bluetooh box was basically free, so I figured why not get it too.
It will probably take me a while to get everything set up, but I'll report back!
- Andy
Time to create page: 1.730 seconds
