CNC Machine EMI Interference prevention
- 7strideR
- Thank you received: 3
27 Nov 2024 03:05 #315346
by 7strideR
Hello,
I am busy converting my Bridgeport Series 1 Interact to LinuxCNC over ethercat. I have a Delta VFD11AMS21ANSAA which can be controlled via and ethernet port (Not sure how hard its going to be to get it working on LinuxCNC)
But as this is my first CNC machine build, what can I do to prevent back EMI and cross talk between the VFD and the other components like the PC, Servo drives and Beckhoff IO units.
Should the VFD be in a separate Cabinet?
Do I need special Ethernet cables or will normal ones Cat 5e work?
Any tips are appreciated.
CNC Machine EMI Interference prevention was created by 7strideR
Hello,
- Online
- Thank you received: 7505
27 Nov 2024 05:50 #315366
Replied by tommylight on topic CNC Machine EMI Interference prevention
Mains filter, ferrite cores on motor wires wound once or twice, proper grounding on all power modules and drives, signal wires shilded and grounded to one side only prefferably near the inputs, all grounds wired to a single point/rail in the box, avoid ground loops, short cables - never coiled.
- Hendrixx
- Thank you received: 27
01 Dec 2024 13:35 - 03 Dec 2024 05:26 #315752
by Hendrixx
Replied by Hendrixx on topic CNC Machine EMI Interference prevention
Last edit: 03 Dec 2024 05:26 by Hendrixx. Reason: not needed
- Online
01 Dec 2024 14:52 #315755
I am sure he found it as he left a thank you there!
Time to create page: 0.605 seconds
