Problem with stepper motor
- max25
- Visitor
23 Dec 2024 02:29 - 23 Dec 2024 04:43 #317181
by max25
Problem with stepper motor was created by max25
I just upgraded my system to the new linux/CommandCNC and am currently trying to configure/debug it. My A axis motor, which runs the far side Y axis stepper won't run, It is selected in the configurator and it is checked for reverse direction. None of the polarity boxes are checked. I pulled the plug out and tested the resistance as in the manual - I get the result shown, about 2 ohms on either side-by-side test of the outer two plugs and infinite resistance on alternate ones (1st and 3rd or 2nd and 4th). I swapped the two plugs that go to the Y axis so the one that moved was plugged into the socket on the bladerunner box for the one that didn't move and vice versa. I still get no movement on the far side of the table. The last thing I tried was checking the stepper windings with an led, Curiously, the motors that work don't light the led, the motor that isn't working does (both windings light when tested). Seems like it must be the motor but not sure what is wrong with it - anybody have an idea?
Last edit: 23 Dec 2024 04:43 by tommylight. Reason: Link removed
- Thank you received: 7505
23 Dec 2024 04:46 #317184
Replied by tommylight on topic Problem with stepper motor
The above post was stolen from here
www.plasmaspider.com/viewtopic.php?t=24864
And link added to oyosteper . de
They keep posting spam continuously here, and frankly i am not tolerating that anymore as they always hide links and steal posts from other members or other forums, instead of just posting offers or discounts or whatever on the "user exchange" section of the forum.
- timo
- Thank you received: 61
23 Dec 2024 08:05 #317197
by timo
Replied by timo on topic Problem with stepper motor
That explains it. It starts to make sense, that it did not make sense:-).
Time to create page: 0.551 seconds
