Precise Z axis homing reference
28 Dec 2024 12:27 #317556 by karnalta
Precise Z axis homing reference was created by karnalta
Hi all,
I changed a bit my workflow due to the usage of a new GUI (Basic Probe), my new workflow require my machine to have a precise and consistent Z axis zero point.
ATM, I only have a small Omron tactile switch has it was just used as approx. boundaries.
What could I use to achieve a better axis homing ? IR Sensor ? Special tactile switch ?
Any recommandation that doesn't cost an arm and is easy to setup is welcome :)
Thank you.
28 Dec 2024 17:35 #317576 by PCW
Replied by PCW on topic Precise Z axis homing reference
What type of hardware do you have?
28 Dec 2024 20:31 #317585 by cakeslob
Replied by cakeslob on topic Precise Z axis homing reference
You could go with a more precision type of homeswitch like a metrol or something
Or do what real cnc machines do, and set the home using the encoder index channel
29 Dec 2024 07:41 #317604 by karnalta
Replied by karnalta on topic Precise Z axis homing reference
Ok thank you.
I think I am gonna look into precise switch because I know nothing about encoder...
I don't even know if my stepper have an encoder in them, I think it is optional (?).
I run closed loop 48v stepper with CL57T drivers on a Mesa 7ixx.
29 Dec 2024 11:29 #317629 by PCW
There are ways to use homing to index with an added
proximity switch that detects a flag on the stepper shaft.
(this does not require an encoder)
A flag on the shaft with a 1" radius will increase the homing
accuracy by a factor of about 30 (assuming 5mm/0.2" pitch
ballscrew and same linear and flag proximity switches)
Time to create page: 0.629 seconds
