LinuxCnc and Industrial Robot?
- Holzwurm56
- Thank you received: 10
25 Aug 2025 12:56 #333913
by Holzwurm56
LinuxCnc and Industrial Robot? was created by Holzwurm56
Hello, I've seen industrial robots online that were used as 3D printers, for drawing, or for milling. Does anyone have a robot arm like this in use for such an application? Can this be done with LinuxCnc? Which LinuxCnc version would I need? Are there programs for creating toolpaths?
Thank you very much for any answers.
Hans
Hans
- Online
- Thank you received: 7509
25 Aug 2025 15:47 #333920
Replied by tommylight on topic LinuxCnc and Industrial Robot?
I have/had KUKA industrial robots welding and paletizing bricks and sacks with sand, but they used a stripped down version of winxp.
And there are some robots here on this forum running LinuxCNC, just search for Scara robot. Also there should be some configs included with LinuxCNC so you can download the ISO, write it to a USB and boot from it, then run LinuxCNC in sim mode, some sim configs also have visualization so you can see on screen the machine moving.
As for toolpaths, it depends on what you need, some stuff can be done as simple as for a normal router/engraver/plotter, some might need specialized CAM software.
- Thank you received: 4663
29 Aug 2025 15:15 #334121
Replied by andypugh on topic LinuxCnc and Industrial Robot?
See the config
sim/axis/vismach/puma
for an example config including a graphical representation of the simulated robot.
Note that getting the Denavit-Hartenberg parameters exactly right is not a trivial task if they are not provided. (and there are two different conventions for them)
There are a few examples out there. Look on YouTube.
For example:
For example:
- meister
- Thank you received: 502
29 Aug 2025 17:47 #334130
by meister
Replied by meister on topic LinuxCnc and Industrial Robot?
31 Aug 2025 11:17 #334188
The Melfa seems to be all in-line so that makes the kinematics somewhat simpler.
- Thank you received: 2177
01 Sep 2025 07:22 #334225
Replied by Aciera on topic LinuxCnc and Industrial Robot?
It is possible to use LinuxCNC to run cartesian (ie xyz) gcode on an industrial robot. However, since the planner has no information about the kinematics used and 'assumes' a cartesian joint/axes configuration you will not get uniform velocities over the robot's work space.
If accurate path velocities are important for your application then you are going to have a hard time using LinuxCNC with a manipulator.
- heaven
- Thank you received: 3
01 Sep 2025 21:46 #334250
by heaven
Replied by heaven on topic LinuxCnc and Industrial Robot?
One more problem, LinuxCNC is using 3-axis (xyz) readahead, so if you are using xyz+(abcuvw) axis blending in G-code command, the speed will be very slow
02 Sep 2025 07:37 #334267
If the G-code is very short segments, this becomes a limit to the speed. But if the moves are long, the system can run at full speed.
That will depend on the G-code. The slow motion in combined moves is to do with the requirement in the simple path planner that the system can stop in the next segment (if it turns out to be the last segment, because without lookahead it can't know what the allowed exit speed is for the current segment)One more problem, LinuxCNC is using 3-axis (xyz) readahead, so if you are using xyz+(abcuvw) axis blending in G-code command, the speed will be very slow
