VMC Bridgeport 760 22 Retrofit Project
- Mafuba
10 Jul 2026 16:44 #347663
by Mafuba
VMC Bridgeport 760 22 Retrofit Project was created by Mafuba
Heyo anyone that reads this and attempts to pass me some knowlege.
I have been tasked with researching how to Retrofit our VMC Bridgeport 760 with a Heidenhain 370 Control to use Linux CNC. I will continue checking any post related to the topic already on this website along with other websites and stuff. However I figured making a post on a forum for the software we are planning to use would be a great start because I could learn some users here that may be able to help point me in the right direction to start or where they may be good sources of knowledge for a project like this.
We are looking to retrofit after years of using the original electronics because some of those electronics are starting to fail and we'd like to switch over to an easier system for maintenance versus sending these components in for repair or buying refurbished parts. So any information on where to look for knowledge on retrofitting this machine or a machine closely similar to ours would be much appreciated.
Thank you for any information that someone is able to provide.
01 Aug 2026 11:32 #348334
Replied by andypugh on topic VMC Bridgeport 760 22 Retrofit Project
Are you planning to retain the existing drives?
I tink that where you choose to make the cut between old and new would depend on where the electronics failures are happening.
But it is generally best to keep the original motors and often (but by no means always) best to keep the original motor drivers.
Time to create page: 0.154 seconds
