- Thank you received: 10
Help Controller for a Lathe ?
- Holzwurm56
- Topic Author
3 months 1 week ago #348056
by Holzwurm56
Help Controller for a Lathe ? was created by Holzwurm56
Hello, I have a—Belgian?—Gallic 16 NC lathe. When I acquired it, I removed the control system but left the spindle power unit in place. For the control system, I use Mach3 via two parallel ports, UHU drives, and DC servos. I can also turn in a quasi-conventional manner using two electronic handwheels. The whole setup worked well for years, but it is admittedly outdated. Now I have a fault in the original main power circuit. Although I have an old wiring diagram, the actual wiring is a chaotic mess. I am now considering overhauling the main power circuit to make it organized and installing a more modern control system. However, I need to be able to use the two electronic handwheels, as there are no mechanical ones. Does anyone have experience with a control system that is affordable (the machine is 35 years old and could fail completely at any time), supports two electronic handwheels, and doesn't come with a 1,000-page manual?
In my stock is a Mesa 7I96 Eth, can I use it?
Many thanks for any replies,
Hans
Hans
3 months 1 week ago #348057
Replied by tommylight on topic Help Controller for a Lathe ?
Yes you most probably can, as it is controlled by two parallel ports, see what port is wired to drives and remove it, wire drives to Mesa, then get an IDC26 to DB25 adapter cable and use that to wire the second port to Mesa, granted the encoders and maybe inputs are on it.
3 months 1 week ago #348067
Replied by rodw on topic Help Controller for a Lathe ?
This is actually pretty easy, the 7i76e comes with 2 mpg inputs and you can have them on the 7i96 as well but you have to give up a couple of pins or a Stepgen.I can't quite remember what. If you ask PCW nicely, I'm sure he will sort out the correct solution.
Once you have that sorted, there is a good example of a MPG using parallel port pins in the docs. linuxcnc.org/docs/stable/html/examples/mpg.html
But in your case, you can ditch the axis select knob because you will use a dedicated MPG for each axis. Just implement the scale select knob... I have not thought about it but you may be able to use the one scale select for both MPGs. Using digital knobs lets you minimize the number of pins you need for the scale hence the mux4 components.
- Holzwurm56
- Topic Author
3 months 1 week ago #348068
by Holzwurm56
Replied by Holzwurm56 on topic Help Controller for a Lathe ?
Many thanks for every answer. Who is PCW?
Hans
Hans
3 months 1 week ago #348069
PCW = owner of Mesa, Peter Wallace and a very active forum member
- timo
- Thank you received: 49
3 months 1 week ago #348084
by timo
Replied by timo on topic Help Controller for a Lathe ?
Keep us updated what you do there
Keep in mind that the hand wheel can most probably just be connected to "normal inputs" if you want to use dedicated encoder inputs for the spindle or other things, like scales.
- Holzwurm56
- Topic Author
3 months 1 week ago #348086
by Holzwurm56
Hi Timo,
There’s no rush on my end. I want to thoroughly research which control system to use first. The issue seems to be the two handwheels that can be used simultaneously. It worked well with Mach3 using two printer ports, but I’m looking for something more modern.
Hans
Hans
3 months 1 week ago #348088
I don't beleive there is anything stopping you from using 2 mpgs at once. Its just most examples are based on a hand held encoder. See if you can find photos of Andy Pugh's lathe. I think it was a Holbtook. He has the two MPGs on it and he went as far as getting castings made to match the original lathe.Hi Timo,
Hans
- Holzwurm56
- Topic Author
3 months 1 week ago #348092
by Holzwurm56
It`s possible to post photos here? Then I could show some photos of my lathe.
3 months 1 week ago #348094
Yes, use the picture icon above. There is a size limit do I usually download pics from Google photos by right clicking on the photo rather then getting the full size photo which will be too big;
Time to create page: 0.065 seconds
