twin headed hydro punch how to cnc
- jd896
then again i still think what ever figure will need doubling as some beams come from the stockholders with a slight bend we get them through manualy but its a hell of alot harder
but as said above if the drive doesnt have to be anything special then can it be a geared 3 phase motor as i can lay my hands on these then a presume just use a vfd? if i can get it to take a +\- 10 volt signal or am i right in thinking it could take a pwm input ? 7
many thanks john
- Thank you received: 4995
It is just about possible to use a 3-phase motor and VFD to do position control. You need a good VFD though (flux-vector, probably), and 3-phase motors are likely to get hot and bothered at zero speed.
Having it geared will help.
You would normally use a brushed or brushless servo motor for this sort of job.
Likely to be expensive for that sort of torque though. As a random example:
www.inverterdrive.com/group/Servo-Motors...rotherm/default.aspx
And then you need a drive on top.
You probably don't need 4000rpm, (that's 100 6m beams a minute) so a gearbox would make the economics easier.
- jd896
dont ever have much spare time
a few questions:-
would it need to be lader logic to have a solenoid fire and oiler onto the punches say every 15 holes or so
and to control the punches power - have the machine power on if not already for any punch command and then power off again after say 10 mins and have the timer reset every time a punch stroke is requested
am i right in using an o word subroutine for the punch cycles - turn on relay wait for end of stroke switch then release relay then wait for top of stroke switch
and could ngcgui be customised to create the gcode for the machine it woud have to be pretty much a single axis program - dimension to first hole and then an option for centres there after and number of centre repetitions
also could there be away of checking total beam length before any punching -( pull the whole beam through after homing and then measure the length until the beam brake for the home switch is activated indicating the end of the beam)
and then check this against the imputed expected beam length to within + / - 5mm and if it does not meet the tolerance then reject the beam
if the above is mostly correct then i dont think it should be that bad to do after some reading time
- BigJohnT
- Thank you received: 1176
Yea, you can use digital inputs to wait for the stroke to complete.
If you can put it into a subroutine you can do it in ngcgui.
You might do a probe move to determine the length of the beam and compare that to what you expect.
hi again ive been running this through my head and wanting to get the hardware and build the panel and such and get all the software sorted before buying £3500 worth of drives and servos and gearbox'se
I think this is probably wise.
it might be worthwhile buying a small drive + servo pair from eBay to practice with, then either put it back on eBay when finished, or keep for the next job.
The cheapest I can find is www.ebay.com/itm//120624827694
However it is difficult for me to search US eBay as I don't have the ability to ignore shipping, and most things come in at $300+ shipping.
- jd896
andy this might be one for if say the punch units are 600mm apart (fixed at that) and the holes programmed in do or do not match this could a sub for ngcgui or other be written to account for using both punches at the same time/position and if not be used independently and could the sub file make the choice based on if the requested centers would divide into 600
I think that those decisions would have to be made by whatever software created the G-code.
- jd896
i would like to make the machine very user frendly not so the programs have to be made and then saved and loaded and such just input the dims press done and run it till the jobs done
- BigJohnT
Looking at the PDF I see two series of holes so the entries might look something like this:
Distance to first set =
First Set spacing =
Number of holes =
Distance to second set =
Second Set spacing =
Number of holes =
Beam Length =
In the subroutine
Measure beam length
If ok continue
if not quit
do while number of holes in first set > 0
go to first location and punch hole and subtract one from number of holes
go to first offset and punch hole and subtract one form number of holes
do while number of holes in second set > 0
- jd896
i dont know the terminology but could it order the file based on the x position requested ascending/descending
thanks john
