Re:Dahlgren Engraver Z axis air actuation
15 years 8 months ago #7468 by bvandiepenbos
Rick,
Thanks for info and link to the c37 board from cnc4pc.
I wonder if the C9 board would be even better, it uses solid state switching instead of mechanical relay. My thinking is the mechanical contacts might not last long due to the rapid and frequent cycling of tool up/down. A CNC engraving of text would likely have hundreds of cycles.
I will probably order today, although I hate to wait for it to arrive. I was hoping to wire up something myself today from local Radio Shack parts.
This Saturday is a rare time I have "off" to play with this hobby.
~*Brian
15 years 8 months ago #7470 by bvandiepenbos
Thanks John.
great info!
I will study it closer and maybe wire up something of my own today.
the relay board from cnc4pc suggested by Rick G looks good and would be easy.
While I am waiting for it to arrive I might try building my own circiut.
~*Brian
15 years 8 months ago #7471 by BigJohnT
So long as your pneumatic solenoid is DC the C9 will work fine.
Keep us posted on your progress...
15 years 8 months ago #7472 by bvandiepenbos
yes
24vdc 7watts
KIP Brand #241144
3-way N.C.
I will keep you guys posted.
~*Brian
15 years 8 months ago #7473 by bvandiepenbos
ok guys, this is probably a dumb question...
I was just looking at the skematic for my HobbyCNC EZ Motor driver board and wondered if the 6 output wires that would go to a stepper motor could instead be used to trigger my relay?
I already have 9-pin connector on my enclosure where the Z stepper motor would (will) plug into.
sure would nice if I could just wire up a custom 9-pin cable to plug relay into there.
Then when I eventually get z axis motorized I could just plug stepper back in there.
I don't have any idea what comes out those wires to power the stepper, so this might be a really stupid question.
Don't steppers have coils that are energized like a relay coil?
I can easily adjust the amps output to motor... I am guessing relay coil would required less than stepper.
~*Brian
15 years 8 months ago - 15 years 8 months ago #7474 by BigJohnT
My guess is it won't work as the stepper driver turns on and off the coils to make the stepper move...
From the IRC
can a stepper output be used to turn on a pneumatic solenoid?
[11:24] <skunkworks> I think you just would not know what sequence the stepper coils would be in.
[11:24] <skunkworks> at any given time
[11:24] <pcw_home> I guess I could but you need to know which winding is energized, easy for quadrature not for step+dir
[11:24] <pcw_home> ha SW beat me to it
[11:27] <pcw_home> quadrature = "wave mode" = stepgen mode 2
Last edit: 15 years 8 months ago by BigJohnT. Reason: more info from IRC
Time to create page: 0.241 seconds
