Re:Dahlgren Engraver Z axis air actuation
15 years 7 months ago #7630 by Rick G
What are using for a power supply to the C15?
Are the LEDs on the board working?
It could be that the output of your parallel port is too weak, in which case a breakout board that boost the signal is in order or add a second parallel port with a higher output.
Rick G
15 years 7 months ago #7632 by bvandiepenbos
hello Rick,
I am using wall-wart power supply. yes LED is lit.
You are right, I boosted signal to 5v with a powered breakout board, now it works.
Parallel port output measures 2.98v
it works!.... z-.1 =tool down, z0 =tool up
thanks guys.
15 years 7 months ago #7633 by bvandiepenbos
now that my z-air up/down works I need to get relay #2 to turn on my router.
I am using pin 14
how should I activate it from g-code?
~*Brian VanDiepenbos
15 years 7 months ago #7634 by BigJohnT
You might want to put something in your hal to enable disable the output until you know the output direction is correct. You could put a PyVCP checkbox that enables the output after say you jog up or even better us motion to enable it with your first line a Z up. Play with it for a while to make sure you don't get some unexpected results.
15 years 7 months ago #7635 by BigJohnT
Well I just had one of those duh moments. Use the spindle output and use S1 M3 for on and M5 for off.
15 years 7 months ago #7656 by bvandiepenbos
ok, that sounds simpler.
what should I select in step config wizard for my pin 14 to work with M3?
thanks
Time to create page: 0.294 seconds
