MasterCam
  • Mike_Eitel
  • Mike_Eitel's Avatar Topic Author
  • Platinum Member
  • Platinum Member
09 Apr 2010 16:40 #2552 by Mike_Eitel
Replied by Mike_Eitel on topic Re:MasterCam
Hi Guys
Took a while, but in the meantime I finshed my machine.
Status of Mastercam connection seems to be not bad.
I have not yet tested a lot, but basicaly I can generate a ngc file.
As proposed I started with the old pst file and used the mastercam conversion dll....
The file contains all files that I have done special in Mastercam.
Maybe it helps someone, I can not assist, as I'm myself a beginner with CAM.
Regards and good look
Mike
Attachment EMC_mastercam.zip not found
The following user(s) said Thank You: meduag
09 Apr 2010 17:36 #2553 by robh
Replied by robh on topic Re:MasterCam
hi mike
thanks for the update and letting us know how it worked out for you
do you mind if this was added up onto the wiki page to update the one there.
thanks,
  • Mike_Eitel
  • Platinum Member
  • Platinum Member
09 Apr 2010 17:53 #2554 by Mike_Eitel
For sure you can ...
Only I'm not sure if it has " a good quality level" so it makes sence on the wiki.
If you can judge ... feel free anytime
04 Oct 2015 00:47 - 04 Oct 2015 00:51 #63405 by eFalegname
Replied by eFalegname on topic MasterCam
This postprocessor for Mastercam X9 (3-axis) - LinuxCNC is still "work in progress", use with caution.
I have to adjust the use of subprograms and I must say that it does very well its job, it allows you to use all the LinuxCNC work offssets.
Any suggestion is welcome...
Last edit: 04 Oct 2015 00:51 by eFalegname.
04 Aug 2016 12:44 - 04 Aug 2016 12:48 #78355 by eFalegname
Recently I noticed that linuxcnc 2.8 master supports the G52 offsets which was a long awaited and very useful feature.
Guys, could anyone show me how to implement G52 in the Mastercam postprocessor for linuxcnc, any advice will be welcome.
Below I added my mastercam post with subprograms and linuxcnc offsets.
File Name: mx7-linuxcnc.pst.zip
File Size:16 KB
Last edit: 04 Aug 2016 12:48 by eFalegname.
Time to create page: 0.099 seconds
