Blender CAM - new blender addon it's now 2025 ...
13 Aug 2013 08:37 #37605 by iccha
Replied by iccha on topic Blender CAM - new blender addon
Hello, new version is out:
blendercam.blogspot.cz/2013/08/blender-cam-050.html
What is new:
  • Exact mode is now faster by around 25-30 %
  • support for text objects - they kind of worked in some situations but that was a coincidence! :) Now text is properly supported.
  • default threshold for optimisation was lowered, the new algorithm works better with that
  • Waterline with layers was fixed, now waterline works much more like in other CAM programs. It is however still experimental feature!
  • Drill paths now support transformations of the source curve object
  • The
re are not so many changes as usual, but I'm kind of running in summer-mode ;)
captain chaos:
please watch what size of object you input. the default cube in blender measures 2m, so if you test on that, it can run out of memory, because it's huge with the default settings. exact mode however should be able to deal with that too.
30 Sep 2013 23:17 #39421 by iccha
Hello everybody, new version is out again:
blendercam.blogspot.cz/2013/09/blender-cam-060.html
it has bridges and operations chains support.
25 Jan 2014 20:50 - 25 Jan 2014 20:51 #43163 by iccha
Hello, a new release is out:
Blender CAM 0.7.0
Mainly background work, but some optimizations fixes, and some interesting new features - custom cutters, shape packing algorithm being the most fancy ones.
Last edit: 25 Jan 2014 20:51 by iccha.
01 Oct 2014 16:44 - 01 Oct 2014 16:52 #51713 by iccha
Hi, a new release of this addon is out:
blendercam.blogspot.com/2014/09/blender-cam-080.html
a lot of small improvements ;)
Also, I have a question:
Can somebody edit the wikipage about CAM? This page became non-editable a looong time ago, and it is not possible to update the information there.
There are 3 new versions of blender CAM since this page was updated...
Last edit: 01 Oct 2014 16:52 by iccha.
01 Oct 2014 21:57 #51716 by ArcEye
Replied by ArcEye on topic Blender CAM - new blender addon
Anyone can edit the page, I have just logged in and got editing rights.
Click on preferences at the bottom of the page
Put in your user name and a password so someone does not commit carnage under your moniker.
Enter the name of the LCNC mascot in the administrator password field
(if you don't know it, PM me)
That it
19 Feb 2025 13:28 #322012 by stefan63
Blender CAM 2025
Please give some inputs, is it worth the effort to learn?
The following user(s) said Thank You: captain chaos
01 Mar 2025 23:47 #322993 by captain chaos
Replied by captain chaos on topic Blender CAM - new blender addon it's now 2025 ...
thanks I'll have another look at it as I use blender for all my 3d print and cnc drawings and use cam bam or F-Engrave. Maybe start a new blog.
  • Moderator
  • Moderator
02 Mar 2025 10:56 #323026 by tommylight
Replied by tommylight on topic Blender CAM - new blender addon it's now 2025 ...
Blender is a monstrosity and a magnificent piece of software, so yes, it is always worth the time and effort to learn it, not only for CNC.
Time to create page: 0.642 seconds
