Fusion 360 G3 errors SOLVED
13 Jan 2019 11:14 #124071 by Hakan
Replied by Hakan on topic Fusion 360 G3 errors
One thing I can see in the G code is that "J" is used for the center offset of the arc in the X direction. That is wrong, it should be "I". In the G3 lines.
I propose you try the post processor I attached earlier in this thread. Do tool compensation "in computer".
The code that comes out from that one has worked for me the last 500 times or so. No modifcations should be
needed, just run.
Place the cps file somewhere like on the Desktop. When posting, browse and select it.
28 Jan 2019 00:42 #124996 by Roland2161
Replied by Roland2161 on topic Fusion 360 G3 errors SOLVED
I figured it out. So the J was an issue and I got it to post with I. K. So for some reason I need 5 decimal place in order for it to read the radius. I went into the post processor and edited so it would post 5 places. Low an behold it worked. I am now successfully running fusion 360 Thank you all for the help. Now on to figuring out why the Z axis is drifting a few thousands over multiple passes.
13 Apr 2019 07:35 #130760 by pl7i92
Replied by pl7i92 on topic Fusion 360 G3 errors
in the postprozessor area there are modified postprocessors
to solve many issues on linuxcnc from fusion g-code
you may find a better one there
13 Jan 2022 16:59 #231679 by paulsao
Replied by paulsao on topic Fusion 360 G3 errors SOLVED
Hello, I am using the Fusion 360 post-processor for plasma and when I use figures with radii I have the same problem of different arcs, someone can help me with a recommendation or something that I have to modify, thank you very much.
Time to create page: 0.124 seconds
