X origin error when machining
6 years 4 months ago #170912 by bbsr_5a
Hi
first you shoudt realy update your linuxcnc system
in Terminal
sudo apt-get update
sudo apt-get install linuxcnc
the TLO stands for TOOL_Length_Offset G43
6 years 4 months ago #170924 by Aciera
Aha, do you have a tool offset in the tool table for tool1?
6 years 4 months ago #170928 by bbsr_5a
no
Tool1 is in most cases the ZERO tool
you only need this if you got a ATC or a FIXED toolclamp system like BT40 MKxx to change different tools
otherwise you need to mesure by G38 your tool after changing in the programm
or do a Programm for eatch tool
there are multiple ways to get things going
6 years 4 months ago - 6 years 4 months ago #170931 by Aciera
I dont use the AXIS GUI but the user writes that he has a problem with an offset of 35mm in X that should not be there and, well, i see that tool1 is loaded hith a TLO X of -35.707 in the screenshot.
So I would assume that there is an x-offset in the tool table for that tool and maybe that offset should not be there.
[edit]
Also I see that this tool has a z-offset of 0.511 and a diameter of 0.125 which I think is why he is getting the arc error.
So IMHO the values in the tool table might be the problem.
Last edit: 6 years 4 months ago by Aciera.
The following user(s) said Thank You: twatchorn
6 years 4 months ago #170941 by twatchorn
Aciera
Please explain more. Are the possible tool off sets in the Fusion tool setup, or is there tool off set settings in Linux.?
I see in Fusion I have not been using the tool number system and all my tools start with 1- then the description
"So IMHO the values in the tool table might be the problem." what is IMHO?
Sorry I am ignorant on a lot of these things
6 years 4 months ago #170943 by tommylight
Linux = operating system, so it has no offsets
LinuxCNC = machine controller that runs on Linux operating system, Has tool offsets, machine offsets, etc.
IMHO = In My Humbled Opinion
Tool offsets can be seen and edited in the "File>edit tool table", menu in Axis GUI
Time to create page: 0.070 seconds
