X origin error when machining
6 years 4 months ago - 6 years 4 months ago #170945 by Aciera
"IMHO" means "in my humble opinion"
In LinuxCNC there is a tool table where you define the different tools:
linuxcnc.org/docs/2.6/html/gcode/tool_co....html#sec:tool-table
I'm not near my machine and I'm not really familiar with the axis GUI so I can't check how to open it at the moment but you might want to look in the LinuxCNC menu bar.
Maybe the "Machine"-tab.
[edit]
Thanks tomy you write faster than I do.
Last edit: 6 years 4 months ago by Aciera.
6 years 4 months ago #170948 by twatchorn
Thanks guys, I will look tomorrow - its 11:15pm here
6 years 4 months ago #170957 by Aciera
The tool table is for preset tools that are often used either in a tool changer in the machine or in a rack for manual tool change. If you want to use that then the tool tables have to be same in CAM and LinuxCNC and have to correspond to the actual tools in the tool rack.
If you don't use the tool table in your CAM and always use tool1 then the values for tool1 in the tool table inside linuxCNC should be 0. Or you could suppress the call for tool change (t1 m6) in your postprocessor.
6 years 4 months ago #171100 by twatchorn
Hi Guys,
We have success. Tool table had 35.707 in column X on tool 1.
When you say ***If you don't use the tool table in your CAM and always use tool1 then the values for tool1 in the tool table inside linuxCNC should be 0.** Which column where you meaning that I would enter 0? I tried 0 in POC for tool 1 and got no errors. If I try changing tool 2 and 3 POC to 0 it shows the error in the attached screenshot.
Have you any idea how I may have got this off set value in the table? It is only in the last few months I have been having the errors.
Hopefully the radius error is fixed now too.
I had to LOL when you explained IMHO :-) . It is obvious that text English is not my first language! (here is me thinking it might be an other program acronym)
Thank you
Trevor
6 years 4 months ago - 6 years 4 months ago #171105 by Aciera
POC is the pocket number of the tool changer and probably has to be a unique number.
What I meant was all the values for XYZABCUWV and Diam should be 0 or blank. That way there is no danger of unwittingly activating an offset by calling a tool. "Comment" is just that, a description of the tool, you can delete that as well.
"FRONT", "BACK" and "ORIENT" are used on lathes so leave those blank as well.
Your english is fine, its also not my native language. Some know some things and others know other things. Glad you got it working.
[edit]
No idea how you got that tool table messed up. maybe somebody else has an idea as I don't use it.
6 years 4 months ago #171129 by bbsr_5a
if tool table and or VAR files are messed just dlete VAR var.bak tbl file they are regenerated at the machine Load
Time to create page: 0.145 seconds
