Solidcam post for turning
3 years 11 months ago #256443 by Masiwood123
hi guys does anyone use solidcam for lathes? I use it for milling and I have no problems there. Here, I am bothered by why gcode duplicates the x coordinates, given that my ``working zero'' is in the center of rotation,model. Real model is  above 50(54mm cylinder .. x should be 25mm than so it goes towards zero, or more because stock diagonals. but in the gcode it is x80+ to  x12mm ( axis directions on my lathe positioned exactly like this in the picture.Thank you
3 years 11 months ago #256447 by Masiwood123
the smallest diameter on the model is about 12mm..x should be about 6mm, and in the gcode it is also 12, I am not able to set the working zero outside the center of the piece because I set the home switch so that the knife does not cross the center of the axis of rotation.
3 years 11 months ago #256448 by Masiwood123
the diagonal length of the stock is 38mm, so X should go in the positive direction, Z is fine.
3 years 11 months ago #256763 by jtc
Replied by jtc on topic Solidcam post for turning
You are using G7 (Lathe Diameter Mode) on you gcode, So the X coordinate is expressed in diameter of the part.
linuxcnc.org/docs/html/gcode/g-code.html#gcode:g7
The following user(s) said Thank You: Masiwood123
3 years 11 months ago #256764 by Masiwood123
I saw that in practice it's good, just because it's my first time using a lathe it was a little strange, it's good that you told me it's G7, thanks a lot
3 years 11 months ago #256967 by Masiwood123
Masiwood123 post=256955 userid=27761
today I gave birth to a bear..since I combined two operations in gcode, the first one that makes a hole like g17 and the second one that makes an outer contour (put in gcode G7)..however linux sees both operations as g7 so it doesn't make a round hole for me but an ellipse , divide x by 2. Is there a way to make the first operation (see the hole normally, and in the following line to read the lathe operation, with G7) not worth doing separate operations, but would like to place everything in one file? thanks
youtube.com/shorts/w0sIjqA-jdU
Time to create page: 0.195 seconds
