Solidcam post for turning
3 years 11 months ago #257020 by jtc
Replied by jtc on topic Solidcam post for turning
You can work on radius mode putting a G8 on the desired code portion, and after you can work on diameter mode again by placing a G7.
The following user(s) said Thank You: Masiwood123
3 years 11 months ago - 3 years 11 months ago #257041 by Masiwood123
Masiwood123 post=257040 userid=27761
The G8 does the job, it's a round hole now, thank you very much. but I'll have to do it in two separate operations, it's too thin and the processing is bad.. today I successfully made a small adapter for the tailstock that will hold when I do the outer contour...
Last edit: 3 years 11 months ago by Masiwood123.
Time to create page: 0.171 seconds
