STL, STEP or IGES Interface in EMC
- Midnightwolf
28 Oct 2010 14:01 #4935
by Midnightwolf
Replied by Midnightwolf on topic Re:STL, STEP or IGES Interface in EMC
it was just an idea to develop such an "filter" ...
- BigJohnT
- Thank you received: 1176
28 Oct 2010 14:04 #4936
by BigJohnT
Replied by BigJohnT on topic Re:STL, STEP or IGES Interface in EMC
Good idea! It would work for engraving as you follow the line and have a constant depth.
- Midnightwolf
28 Oct 2010 14:15 #4937
by Midnightwolf
But isn't enough for my STL models....
Ok... I will take a licens for CUT3D in the next step. That will be the only way to translate my 3D models...
PyCAM is good for "easy" models... that will be fine for the first tests on my self made portal machine...
- Thank you received: 4995
28 Oct 2010 15:15 #4939
Replied by andypugh on topic Re:STL, STEP or IGES Interface in EMC
Midnightwolf wrote:
Have you looked at HeeksCAD? (I admit I haven't looked for some time)But isn't enough for my STL models....
- Midnightwolf
29 Oct 2010 05:22 #4953
by Midnightwolf
Hi Andy,
yes I had a look into HeeksCAD. It's a little bit strange to use.... Also I had some trouble with the handling.
Regards
Benjamin
Regards
Benjamin
- Der3er
- Visitor
02 Nov 2010 10:34 #5015
by Der3er
Replied by Der3er on topic Re:STL, STEP or IGES Interface in EMC
Well, a step or iges based cam module that would allow for even fairly basic toolpath strategies would certainly be GREAT! Obviously, it is not just an import filter but rather a complex affair as it should address at least some of the basic toolpath issues. And these are manifold. But still: It seems somewhat unreasonable to use either very expensive or very cheap software cam-packages that in their way will not fit the bill of most emc users. As of now I'm using cut3d and vcarve pro, they work well most of the time. BUT: the toolpath strategies are somewhat inferior -as one would expect, actually, at that price- and sadly it takes me more time to get the toolpaths done than designing my models in the first place.
A word of advice about cut3d: This is rather an ameteur-tool. It puts out toolpaths, yes. But do not expect something that will equal those from real world production packages. My 2 cts
